You are here: Home / Networking + IoT / Mitsubishi Electric Automation Debuts Ethernet Communications Adapter for PLCs
August 23, 2012 By Stacy Combest Leave a Comment
Mitsubishi Electric Automation has an Ethernet adapter for its FX3 Series PLCs. The FX3U-ENET-ADP can be a cost-efficient alternative to micro PLCs to connect equipment such as PLCs, HMIs and personal computers, and has a built-in data monitoring tool so users can view real-time status and current data values of their equipment.
fx3u-enet-adp1
The FX3U-ENET-ADP features easy setup through standard programming software, four-channel communications for access to a wide range of devices, and an embedded data monitor for viewing network status using just a web browser. The adapter interfaces easily with other control systems and connects with most modular machine components to deliver detailed information about network conditions. It uses GX Works2 to create a direct connection without setting any IP addresses, and automatically synchronizes a PLC’s internal clock to an SNTP time server.
www.MEAU.com
Filed Under: Networking + IoT, PLCs + PACs Tagged With: Mitsubishi Electric
