You are here: Home / Motors / New 60-mm OD frameless brushless servo motor kits from Maxon
January 30, 2018 By Miles Budimir Leave a Comment
The new EC 60 Flat Frameless Brushless Servo Motor Kit from Maxon consists of only a rotor and stator – with no bearings or motor shaft. With an outer diameter of only 60 mm, these pancake servo motor kits are extremely compact.
Available in size ranges from 70 W to 100 W, these EC (electronically commutated) frameless slotted motors feature low-voltage windings, high pole pair count and are shipped as BLDC frameless motor kits.
The motor features include:
  • Low-voltage windings
  • High accel/decel capabilities
  • Low rotor inertia
  • High pole pair count
  • Lower cost vs. slotless motors
The flat design, high torque output and hollow-shaft construction provides plenty of space for cable glands which allows for a high level of integration into OEM applications such as collaborative and mobile robots, AGVs, exoskeletons and embedded robotic applications.
For more information, visit www.maxonmotorusa.com.
Filed Under: Brushless Motors, Motors, Servo Motors Tagged With: maxon
