You are here: Home / Mechanical PT / New ultra-light weight gearheads from Harmonic Drive
September 17, 2020 By Miles Budimir Leave a Comment
The new CSF-ULW ultra-light weight gearhead series from Harmonic Drive LLC features a newly engineered lightweight structure with an ultra-compact shape.
The CSF-ULW is a housed zero backlash Harmonic Drive component gearset combined with a precision cross roller output bearing and flange. The CSF-ULW is available in two sizes, with three reduction ratios per size. The ULW series maintains the same performance standards as the popular CSF-2UH series.
gearheads
Ideal for use on end-of-arm axes for small industrial and collaborative robots, the CSF-ULW is also well suited for general industrial machinery where weight is a critical factor.
Features include:
  • Zero Backlash
  • Accuracy <1 arc-min
  • High torsional stiffness
  • High efficiency
  • Smooth operation
  • Robust cross roller output bearing
For more information on the CSF-ULW ultra-light weight gearhead series click here.
www.harmonicdrive.net
Filed Under: Gears + Gearing, Mechanical PT Tagged With: Harmonic Drive
