Force Control Industries presents their Posidyne X Class Clutch Brakes which feature Oil Shear technology that allows rapid and precise stopping, starting, reversing, speed change and positioning – all without adjustment and virtually no maintenance. Well suited for applications with frequent start/stop cycles, these unique motion control devices allow higher cycle rates (as high as 300 cycles per minute), and unparalleled service life (20 to 40 million cycles) to increase production rates with lower downtime. With unparalleled speed and precision, the value engineered X Class Clutch Brakes allow machine designers to run at higher cycle rates and quality levels or design new machines for higher performance at a reasonable cost.
The Posidyne X Class features an innovative Split Clamped Quill feature, which reduces shaft and key/keyway damage to the motor shaft associated with competitive clutch/brakes. The split quill collar tightens the quill 360 degrees around the shaft and key for superior connection.
Convenient options such as foot mounting kits, manifold mounted valves and optical encoders with closed-loop positioning controls are available to fit most applications. The totally enclosed Posidyne X Class is impervious to dust, dirt, and chips. With a washdown or marine duty option they are resistant to chemicals, coolants, caustic wash down, weather and more, making them suitable for hostile environments. They are also inherently explosion proof with the addition of an explosion proof actuation valve. A standard valve could also be remotely mounted in an explosion proof cabinet.
All Posidyne clutch/brakes are designed with low inertia cycling components. This makes them even more efficient, requiring less motor horsepower to accelerate the load, and less torque to stop the load. By reducing the motors’ high inrush currents and the associated power factor imbalance, these unique clutch/brakes can provide significant energy savings in 24/7 manufacturing demands.
A simple actuation system allows torque in the clutch and brake to be precisely controlled through air or hydraulic pressure control. Adjustment for rapid or soft starts and stops is easily accomplished. Manifold-mounted control valves reduce response times by eliminating hoses and fittings while providing a space efficient design.
The Posidyne X Class clutch/brake can be actuated either by air or hydraulic pressure for use in plant or outside applications. The hydraulic actuation package includes a hydraulic pump, solenoid valve, regulators, and a filter. A heat exchanger can be added for additional cooling for unusually high loads or cycle rates.
For more information, visit www.forcecontrol.com.
