You are here: Home / Controls / PCL61x4 series high-performance servo/stepper controller chips from Nippon Pulse
April 27, 2015 By Patrick Curran Leave a Comment
Nippon Pulse has released its newest series of motion controller chips, the PCL61x4 Series. PCL61x4 is a series of two high-performance servo/stepper controller chips: the PCL6114 single-axis chip and the four-axis PCL6144 chip.
The PCL61x4 series has some improved features over the PCL61x3 series, a similar chip series in the Nippon Pulse family of products. The most important new feature is the available SPI serial bus for 4-wire connection to augment the existing 8/16-bit parallel bus. The PCL61x4 series also features programmable software limits and 27 event factors – four more than the PCL61x3 series – in order to initiate interrupt signal output. In addition, the new series maintains all the same advanced features as the PCL61x3 Series: built-in pre-registers for continuous operation, linear interpolation, nine major operating modes, and input terminals for manual pulsers, jog switches, and limit/homing switches.
Nippn-Pulse-PCL61x4-Two-Chip-Series-controller-chips
This chip series will benefit Nippon Pulse customers who require improved operational control and faster motion for their applications. The chips work well with high-speed, high-resolution linear motors in industrial settings. They make ideal controllers for our Linear Shaft Motors in high-precision applications such as semiconductor processing or microscopic image scanning.
All chips in both the PCL61x4 and PCL61x3 series are RoHS compliant.
Nippon Pulse America Inc.
www.nipponpulse.com
Filed Under: Controls, PLCs + PACs Tagged With: Nippon Pulse
