Greenville, Del. — Servo2Go.com announces the release of the FSBR series of Reverse Mounted Spring Applied Brakes from Inertia Dynamics of New Hartford, CT, designed to handle the most demanding of brake applications.
The FSBR brakes are designed for applications requiring minimum space (short axial length) or on motors with short shaft extensions. When mounted, the armature hub is installed on the shaft first, then the brake is installed over the hub and attached to the motor.
The FSBR brakes are rated up to 100 lb-in static torque, and fit motors up to 5.3 in. outside diameter.
For more information, visit http://www.servo2go.com/product.php?ID=100509&cat=10019
