You are here: Home / Mechanical PT / Gears + Gearing / 2-Day delivery for stainless steel worm gear reducers
Boston-gear-700-Series-worm-gear-reducersCatalogued models of Boston Gear’s popular stainless steel 700 Series speed reducers are now available with standard 2-day delivery. Process improvements have yielded the industry’s best standard lead time for stainless steel worm gear reducers.
Boston Gear’s SS700 Series, the original “domed crown” stainless steel reducers, are designed for maximum corrosion resistance and superior performance in high-pressure food processing and packaging washdown applications.
A convenient after hours/holiday hotline is also available for emergency orders. Catalogued SS700 Series models are stocked at local and regional distribution centers to ensure fast delivery.
All SS700 models are NSF Certified and have many maintenance-friendly features including electropolished exterior finish, sealed motor flange, and covered hardware. To prevent miniscule niches that can host microbial contamination, the nameplate has been laser marked to provide a smooth uninterrupted surface. A large internal oil reservoir, filled with H1 food-grade lubricant (Klubersynth UH 1 6-460) and sealed for life, allows for a wide range of operating temperatures and extended service life.
Boston Gear
www.bostongearss700.com
Filed Under: Gears + Gearing Tagged With: Boston Gear
