You are here: Home / Networking + IoT / I/O / 22mm Plastic Pilot Devices
22mm_plastic_pushbuttons_300dpi
AutomationDirect now offers a full line of 22mm plastic pilot devices. The devices, including pushbuttons, selector switches and joysticks, are made with fiberglass reinforced thermoplastic.
Illuminated and non-illuminated pushbuttons are available in six colors and come with either one normally-open or one normally-closed contact block. Illuminated and non-illuminated selector switches are available in two and three-position as well as key operated versions. Joysticks come in either two-position or three-position versions with either maintained or momentary operation mechanisms. Two position joysticks come with two normally-open contacts while three-position models have four normally-open contacts. All 22mm plastic pilot devices are UL listed, CSA certified, RoHS and CE compliant.
More information is available at www.automationdirect.com/22mm-plastic.
Filed Under: I/O Tagged With: AutomationDirect
