You are here: Home / Integrated Motion Systems / Gantries + Stages / 5-axis stage with closed-loop motors for high-precision positioning
F-122-compact-5-axis-motorized-fiber-positioning-system-highresPI (Physik Instrumente) LP offers a compact 5-axis stage for precision alignment and positioning required in fields such as fiber-optics and photonics. The modular, 5DOF motorized stage consists of a 3-axis linear module and two goniometers. A multi-axis controller and software with automated alignment functionality is also available. Sub-micron precision is guaranteed by highly accurate mechanical components and encoder feedback for closed-loop operation.
Multi-Axis Stages
PI provides a variety of multi-axis motion systems, including dedicated parallel-kinematics-based high-speed photonics alignment systems with up to 18 axes.
Working with You
PI’s in-house engineered systems and components have enabled customers around the world to increase their productivity and technological advantage for 5 decades. With a large basis of standard precision motion products and proven methodologies, PI is in the position to quickly modify existing designs or provide a fully customized OEM solution to fit the exact requirements of your application from the whole motion range from finger-tip sized nano-positioners to large scale stages with long travel ranges, through a plethora of different drives and guiding systems.
PI
5-axis stage»
Filed Under: Gantries + Stages Tagged With: pi
