You are here: Home / Motors / Stepper Motors / Applied Motion Products introduces integrated StepSERVO motors
★ By Andrew Zistler Leave a Comment
advasdvavIdeally suited for applications such as packaging and labeling, automated test and measurement, automated assembly and life sciences, StepSERVO motorsfrom Applied Motion Products provide the next evolution integrated step motor technology. Starting with a proven integrated motor design, we add a high-resolution incremental encoder and closed-loop servo firmware to create a motor that offers the best step motor performance available today. StepSERVO motors offer the same high-torque-at-low-speed and excellent holding torque characteristics of open loop stepping motors with the advantages of true closed-loop control.
These advantages include the ability to create peak torques from the motor up to 50% higher than the normal torque range of the same step motor running open loop. Closed-loop also means the motor only draws current when it needs it, so step motors now run cooler than ever before. StepSERVO motors feature:
· NEMA frame size 17, 23 and 24. StepSERVO motors utilize 5000 line incremental encoders (20,000 counts/rev)
· NEMA frame size 11. StepSERVO motors utilize 1024 line incremental encoders (4,096 counts/rev)
· Closed-loop servo control using high torque step motors
· High acceleration for faster machine cycles and greater productivity
· Energy efficient, cool running
· All-in-one compact solution
· IP65 versions for wet and dusty environments
· Stand-alone operation (stored Q programming)
· EtherNet/IP industrial networking option
· CANopen fieldbus option
· Modbus RTU option for easy PLC/HMI connection
http://www.applied-motion.com/
Filed Under: Stepper Motors Tagged With: Applied Motion Products
