You are here: Home / Controls / ATEX-Rated High-Temperature Hazardous Location Positioner from Exlar
Chanhassen, Minn. – Exlar’s EXP-24 Positioner conforms to both ATEX (Directive 94/9/EC) and CSA regulations for explosion-proof applications, and can be used to control most of the company’s three-phase linear and rotary actuators, including the EL100 linear and ER115 rotary actuators.
Housed in an IP66-rated enclosure, the Exlar EXP-24 Positioner integrates a fully featured 24VDC motion controller and brushless servo motor amplifier, and is able to power most resolver feedback brushless motors on the market. With an operating temperature range of -29 to 82°C, the EXP-24 is ideal for process control applications and provides the functionality to position a valve or damper by following an analog input signal and providing position feedback via an analog output. For other applications, additional motion modes are available to accommodate the widest possible range of motion control applications.
Designed for analog control, the EXP-24 also includes an isolated RS485 Modbus serial interface for easy integration into factory-wide process systems. Several diagnostics features are available including real time monitoring, following error, position error, input and output status, communication diagnostics, a multi-channel oscilloscope and data logger.
The EXP-24 is set up via Windows-based software. The software lets users select all aspects of configuration and control required for operation. Tabbed pages provide access to input all of the parameters necessary for configuration of valve control or general motion control applications and further simplify the set-up process.
www.exlar.com
Filed Under: Controls, Stand-Alone Controllers
