You are here: Home / Featured / Beckhoff introducing XTS, EtherCAT G, and TwinCAT Vision to the U.S. at Pack Expo
July 16, 2019 By Lisa Eitel Leave a Comment
To revolutionize packaging machine flexibility, scalability and energy efficiency, Beckhoff Automation will launch the eXtended Transport System (XTS) into the U.S. market at Pack Expo 2019 in Las Vegas. Visitors to booth LS-6149 in the Las Vegas Convention Center’s lower south hall will also experience the North American debut of TwinCAT Vision software, which introduces system-integrated vision technology for packaging machines. Beckhoff will also showcase a full lineup of updated automation hardware, software, and gigabit communication via EtherCAT G for packaging machinery during the show — running September 23 to 25 and expected to draw 30,000 attendees.
XTS: the American packaging industry’s next step forward
Now available in the U.S., XTS combines the advantages of rotary and linear motion principles into a best-of-breed linear transport system that provides paradigm-shifting capabilities for packaging machines and smart factories.
The mechatronic solution enables intelligent material flow, exceptional precision, real-time robotics integration and efficient self-reconfiguration based on lot, recipe or other product specifications. Highly customizable and durable motor modules, mechanical guide rails and wireless movers integrate the necessary power electronics, EtherCAT communication and position measurement in a compact form factor, reducing machine footprint up to 50%.
XTS movers can be controlled with high dynamics at velocities reaching 4 m/sec and acceleration exceeding 100 m/s2. Modular linear motors and rails can create circles, clothoids and S-curves as well as straight, open segments. Supporting installation horizontally, vertically or at angles, tracks can be combined to dynamically manipulate or transport parts with multiple movers. Flexible mass production down to lot size 1 is possible through XTS along with EtherCAT networking, PC-based control hardware and TwinCAT 3 automation software from Beckhoff.
TwinCAT sets its sight on machine vision
Beckhoff will also showcase new TwinCAT Vision software, which adds comprehensive image processing into the range of machine control programming and runtime in TwinCAT 3. Machine vision is becoming indispensable in packaging operations for implementing Industrie 4.0 concepts, real-time synchronization, track-and-trace and quality optimization. TwinCAT Vision simplifies design of these functions; it enables users to harness the benefits of GigE Cameras on diverse machines and lines without requirements for separate, third-party vision systems or programming by outside experts.
The universal TwinCAT engineering environment and runtime permit vision system programming and implementation using languages that controls engineers are familiar with, such as those standardized in IEC 61131-3. With a fully integrated vision solution, TwinCAT offers an end-to-end software platform complete with PLC, motion control, robotics, high-end measurement technology, HMI, IoT and machine learning.
Complete automation platform for today’s packaging challenges Visitors to the Beckhoff booth at Pack Expo will also get updates on new EtherCAT solutions, including EtherCAT G and G10, TSN-ready I/O, ELM high-end measurement modules and TÜV-certified TwinSAFE hardware for integrated machine safety architectures. EtherCAT G and EtherCAT G10 will provide communication at 1 and 10 Gbit/sec respectively, in conformance with the IEEE 802.3 Ethernet standard. An innovative branch controller model supports parallel operation of standard 100 Mbit/sec segments with EtherCAT G or G10 as the main trunk, or vice versa. With incredible flexibility, transmission speeds and bandwidth, EtherCAT G enables packaging operations to implement smart factory concepts with high° of machine learning, vision or high-end motion control, including XTS technology.
Other Pack Expo highlights include a wide array of new PC-based control hardware and accessories, including CU81xx Uninterruptable Power Supply (UPS) Modules and CU8210 WLAN devices. The CU81xx series provides 24 V DC uninterruptible power to Beckhoff components and connected devices, particularly industrial, panel and embedded PCs, and initiates data saving, transfer of processes to defined states and safe shut down if external supply fails. Plugging directly into an Industrial PC’s USB 2.0 port and protected by a durable dome, new CU8210 components offer a high-performance and backward-compatible wireless client with encrypted data exchange up to 433.3 Mbit/sec and support for 20, 40 and 80 MHz transmission bandwidths.
The ultra-compact C60xx series Industrial PCs will return with the new C6032, which offers the same quad-core, 3.6 GHz Core i7 processors as the powerful C6030 IPC but with two additional PCIe compact module slots. Modular AX8000 Servo Drives and the AMP8000 Distributed Servo Drive System, which integrates a servo drive directly into a compact servomotor and provides power and communication in one cable via EtherCAT P, round out the motion control lineup.
“The Beckhoff innovations on display at Pack Expo 2019 will help packaging professionals meet ever-increasing demands for flexibility, throughput and compact footprint that are only possible with greater implementation of smart factory and Industrie 4.0 concepts,” said Kevin Barker, president of Beckhoff Automation LLC. “The capability of XTS to revolutionize packaging machines and systems has reached the U.S. market at an opportune time. By adding this dynamic mechatronic system, along with TwinCAT Vision and EtherCAT G, to the robust automation and controls portfolio, Beckhoff more empowers engineers to design new, globally competitive machine designs that can conquer today’s greatest challenges in the packaging industry and beyond.”
Filed Under: Featured, Industrial Automation, Integrated Motion Systems Tagged With: Beckhoff
