You are here: Home / Motors / Gearmotors / Bison Gear’s VWDIR20 Parallel Shaft AC Gearmotor
St. Charles, IL –  A new parallel shaft AC gearmotor available in eight standard models is the latest addition to the expanding Von Weise Drop-In Replacement gearmotor line of Bison Gear & Engineering Corp. The new VWDIR20 AC gearmotors feature 1/4 horsepower (186 watts) 115V, 60 Hz split phase electric motors. The compact, integral gear reducers feature a phenolic high speed gear for low noise and steel gearing in subsequent stages, with ratios ranging from 14:1 to 286:1. Corresponding fixed output speeds are from 120 to 6 RPM, with continuous torque ratings from 100 to 600 in-lbs (11.3 to 67.8 N-m). The gearmotors feature built-in face and fount mounting, with overhung load (OHL) capability up to 300 lbs. (136.4 kg.).
The new VWDIR20 AC parallel shaft gearmotors are designed for high torque, single phase commercial and industrial applications such as electromechanical pool covers and bleachers, compactors, can crushers, conveyors, commercial garage door operators and a wide variety of poultry and other agricultural equipment.
U.L. and CSA recognition are standard and CE recognition can be provided for OEMs. Bison Gear’s Innopreneurial(TM) application and design engineering capabilities to customize standard models to meet specific OEM needs are readily available. All of the VWDIR gearmotors are manufactured in Bison Gear’s suburban Chicago facility to Bison’s high quality standards in order to ensure a short supply chain and reliable, long-life operation.
The VWDIR20 AC gearmotors are the latest addition to Bison Gear’s comprehensive line of Von Weise Drop-In Replacement gearmotors.
Bison’s VWDIR line now includes right angle, parallel shaft and offset parallel shaft designs utilizing AC, DC and universal motors from 1/30 to 1/2 horsepower (25 to 373 watts), with fixed output speeds from 1.5 to 181 RPM and continuous torque ratings up to 800 in-lbs (90.4 N-m).
www.BisonGear.com
Filed Under: Gearmotors, Gears + Gearing, Mechanical PT Tagged With: bison
