You are here: Home / Mechanical PT / Bush and shaft assemblies feature 4-micron clearance
NB Corporation’s FIT Series of slide bush and shaft assemblies optimize clearance between shaft and bush by offering clearances of 4 microns.
Shaft end placement deviation is reduced 70% from the standard 0.046 mm when compared with the FIT Series which is only 0.011 mm.
Because NB achieves a perfect fit, designers can take advantage of the cost savings afforded by specifying a standard slide bush, slide rotary bush or stroke bush rather than designing in clearance adjustable housings and trying to make do.
For more information and details on the FIT Series, visit www.nbcorporation.com.
shaft assembly
Filed Under: Mechanical PT
