You are here: Home / Encoders / Draw-wire encoders from SIKO measure position, speed and inclination
SIKO’s PURE.MOBILE series, the SG31 and SG61 wire-actuated encoders, feature a maximum measuring length of 3 to 6 m. Integrating the latest generation of inclinometers, they combine the ability to detect not only position and speed, but also the measured variable of inclination. The two wire-actuated encoders are complemented by the large SG121 and SG150 variants, which offer a maximum measuring length of 12 and 15 m respectively.
The integrated single-axis inclinometer is available as an option and measures inclinations in the range of ± 180° with a resolution of up to 0.001° and a precision of ± 0.2°, meaning that the sensor can detect even minor displacements. Its integrated temperature compensation keeps the values stable over the entire measurement and temperature range. The sensor data is transmitted to the controller via CANopen, CANopen Safety or SAE J1939 interface independently of the position value.
encoders
Thanks to the modular sensor design, the inclinometer can be integrated into every SIKO draw-wire encoder without changing the sensor’s design, size or connection type. Increasing the range of functions helps reduce machine-related installation space, installation effort and product costs.
The SG31 and SG61 draw-wire encoders are also available in a redundant and a non-redundant variant for position and inclination detection. This means they can also be used for safety-critical applications up to performance level d.
All PURE.MOBILE sensors have been developed according to the requirements of mobile machines and feature an extremely robust design. This includes E1 certification from the German Federal Motor Transport Authority as well as high EMC, shock and vibration resistance. Protected by their compact housings, the sensors consistently deliver reliable and precise values even when exposed to harsh environmental conditions.
For more information, visit www.siko-global.com.
Filed Under: Encoders, Industrial Automation Tagged With: Siko GmbH
