You are here: Home / Mechanical PT / Bearings / DualVee® Washdown Wheels Protect Against Ingress of Liquid
Applications in washdown environments typically require frequent bearing replacement due to the ingress of highly corrosive fluids and loss of lubrication. Bishop-Wisecarver’s new DualVee washdown wheels can increase replacement intervals nearly three-fold, and are interchangeable with standard vee wheels for ease of replacement.
bwc-mc-tips-1
The patent pending design features an all stainless steel construction, FDA approved grease, and an outer shield and inner seal for exceptional protection from liquids and debris. The unique outer shield acts as a momentary seal when subjected to a stream of high velocity fluids, while the inner seal prevents liquid from entering the wheel, and retains the internal lubrication grease.
bwc-mc-tips-2
For more information on how it works, visit www.bwc.com/products/dual-vee.html
Filed Under: Bearings, Linear Motion Tagged With: Bishop-Wisecarver (BWC)
