You are here: Home / Motors / Economical brushless dc motors for large quantity production from Nanotec
With the DBL36, Nanotec now offers a brushless dc motor that is designed for large quantities.
The DBL36 is available in three lengths with a rated power of 7.5 W in size S, 18 W in size M and 33 W in size L. These electronically commuted 3-phase motors are equipped with three Hall sensors that provide information on the rotor position. They are characterized by high efficiency and, thanks to their precision ball bearings, smooth running characteristics.
BLDC motor
The rated speed of this BLDC motor is 4,800 rpm for sizes S and M and 4,500 rpm for size L; its rated voltage is 24 V. With a rated torque of 1.5 to 7 Ncm and a diameter of 36 mm, the DBL36 is an extremely economical solution for a wide range of applications.
The winding can be adapted to other rated speeds and voltages in series production.
For more information, visit www.nanotec.com.
Filed Under: Brushless Motors, Motors
