You are here: Home / Linear Motion / Actuators / Enhanced Harmonic Linear Belt Drive Actuators from OEMDynamics
Santa Clara, Cal. – OEMDynamics, a division of Animatics Corporation, announces enhanced features on the HLD60-H3 actuator. Enhanced features include no gearheads required, which saves money and reduces maintenance, and no brake required in many vertical applications.
Due to its unique harmonic principle, the H3 belt achieves a gear reduction equivalent of up to 40:1 without the need for a gearhead, which means cost savings as well as decreases in space and weight requirements.
The HLD60-H3 can achieve lengths greater than 3m without attributable losses in performance and can be used in a wide range of applications. It also has a sturdy and seamless magnetically retained seal strip and meets European Machinery Directive 2006/42/EC.
www.oemdynamics.com
Filed Under: Actuators
