You are here: Home / Mechanical PT / Gears + Gearing / GAM Gear Introduces the 2010 Gear Reducer Catalog
Mount Prospect, IL – GAM Gear, LLC has released a new 2010 Catalog of Gear Reducers/Torque Converters and Linear Mounting Kits. The 2010 GAM Gear Catalog includes 6 complete new series of products.
The new 2010 GAM Gear catalog includes information on: a new line of low-cost high performance planetary gearboxes (PE-Series), a complete new range of bevel-gear reducers with or without an integrated motor mount (VC-Series and V-Series), a new hollow-shaft-low-cost-hypoid gearbox (DL-DH), and 2 new flange-style gearboxes (right angle DS-DF, and in-line FP-KB).
The 2010 GAM Gear catalog also includes information pertaining to the Linear Slide Kit product (LSK). The LSK is a line of motor mounting kits designed to mount any motor or gearbox to any linear belt or ball screw actuator. The LSK range also includes a unique hollow-output-planetary gearbox designed specifically to mount to linear actuators. GAM provides all engineering and manufacturing for the mating kits and ships within 5 days from order.
GAM Gear, LLC
www.gamweb.com
Filed Under: Gears + Gearing, Mechanical PT Tagged With: GAM
