You are here: Home / Motors / High Efficiency 22mm ECS Brushless Slotless Motor from Portescap
Portescap introduces the 22ECS brushless motor. Designed to deliver exceptional efficiency in high speed applications, the 22ECS runs up to 30 percent cooler than similar motors, at speeds greater than 50K RPM.
ECS-S-seriesAs a result, this brushless slotless motor stays much cooler and offers greater power density than equivalent models at a given operating point. The 22ECS also uses unique high performance lubrication and ball bearings to extend motor life and maximize performance at high speeds. Due to its high power, efficiency and low rotor inertia, the 22ECS can change speeds and accelerate rapidly.
The superior efficiency of the 22ECS brushless slotless motor not only enables cooler operation at high speeds, but also offers battery capacity and life advantages. The motor’s superior efficiency allows battery operated applications to run longer between charging cycles and can reduce the size of the battery needed, allowing mobile devices using the 22ECS to be smaller and lighter.
The 22ECS motor is specifically designed to meet stringent medical market requirements. The 22ECS is best suited for medical ventilation or portable hand-tool applications. This brushless slotless motor can be supplied with a PCB built-in temperature sensor to enable continuous temperature monitoring during peak power operation.
Portescap is globally ISO 9001:2008 certified, and our production site in India is also ISO 13485, ISO14001:2004 and OHSAS 18001:2007 certified.
Portescap
www.portescap.com
Filed Under: Motors Tagged With: Portescap
