You are here: Home / Encoders / HS35 Programmable Encoders from Baumer Offer 60 Arcsecond Accuracy
Southington, Conn. – Baumer announces its new HS35 family of incremental hollow shaft encoders, including a fully programmable version, for heavy-duty positioning and speed-control applications. Available in an IP67 version, these rugged encoders withstand shocks up to 200g, high-pressure cleaning, and ambient temperatures from -40°F to +212°F. The encoders’ ultra-precise optical scanning system delivers unrivaled positioning with accuracy to 60 arcsececonds.  Rugged, accurate Baumer HS35 encoders are available in programmable square wave, square wave and sine wave versions.
The HS35 encoders are available for shaft diameters from 0.5 to 1.0 in. and can be customized further via shaft insert adapters. These isolation shaft inserts provide electrical isolation against voltages up to 2.5kV, preventing bearing corrosion and wear. The encoder’s ShaftLock system with its large diameter between ABEC5 bearings allows the shaft to reliably endure high mechanical loads even at speeds up to 5,000 rpm and 60 arcseconds or better accuracy.
The heavy-duty design of the HS35 encoders includes extra durable castings and wall structures that withstand long-term exposure to harsh environments. Dual seals, lubricants and a durable powder coating on the bearing housing and cover effectively protect against corrosion and allow operation in nearly all environmental conditions. In IP67 versions, high-performance impermeability seals protect against high-pressure wash down. Tether mounting allows for easy installation.
The HS35P offers fully programmable resolution, index, and outputs, allowing customization and minimizing encoder inventories. The resolution is PC programmable to between 1 and 8,192 ppr in increments of one. Zero pulse position/width, HTL/TTL outputs and rotational direction are also programmable. The encoder can be programmed directly via the supply line using the user-friendly software.
Designed to endure extreme mechanical strain, Baumer HS35 encoders are ideal for motor and drive control in a range of heavy duty applications including oil and gas processing, wind power, food and beverage processing, metalworking, printing, packaging, material handling, solar/PV module manufacturing, textile processing, wood/lumber processing, and heavy equipment such as cranes, hoists, elevators, and service vehicles.
For more information on Baumer’s HS35 hollow shaft incremental encoders, visit www.baumer.com/hs35.
www.baumer.com
Filed Under: Encoders, Rotary Encoders Tagged With: Baumer
