You are here: Home / Linear Motion / Actuators / Hygienic Green Drive Linear Actuator from Nippon Pulse
Radford, Va. – Nippon Pulse’s new Hygienic Green Drive, a stainless steel linear actuator, is suitable for integration into food grade and pharmaceutical applications as well as applications in cleanroom environments. The Hygienic Green Drive has an IP69K rating and is ideal for harsh and washdown environments. It features FDA food grade certified guides. Like the standard Green Drive, the Hygienic Green Drive offers built-in feedback electronics, including position sensors, interpolation electronics, and temperature sensors.
The Hygienic Green Drive is available in two different model sizes, a 16mm shaft diameter and a 25mm shaft diameter. Available with a variety of coil windings, the Hygienic Green Drive features rated forces between 8.4 and 96.1N, acceleration forces (peak force) ranging from 33.7 and 384.5N for 40 seconds, and rated currents between 0.53 and 1.85A.
For more information on the Hygienic Green Drive or other Nippon Pulse products, visit www.nipponpulse.com.
Filed Under: Actuators, Linear Motion
