You are here: Home / Integrated Motion Systems / Gantries + Stages / Integrated 3-Axis Micro-manipulator from Steinmeyer
Burlington, MA –  Steinmeyer, Inc. introduces the MP63 3-axis micro-manipulator module. The MP63 is a fully enclosed 3-axis positioner with 25mm stroke in each direction. Included inside the compact precision assembly are DC gearmotors, rotary encoders, lead screws, and non-contact limit switches.
MP63 Image
Accuracy in each direction is 5 microns with ± 1 micron repeatability and standard straightness and flatness is ± 3 microns with 1 micron available as an option. The entire assembly weighs only about 2kg. Cable connectors are located on one end for convenience and simplicity and as an option, the assembly can also be made clean room compatible.
For more information on the MP63 or other products, contact Steinmeyer at 1-781-273-6220 or visit the Steinmeyer group web site at www.steinmeyer.com.
Filed Under: Gantries + Stages, Gearmotors Tagged With: stage, steinmeyer
