You are here: Home / Controls / Integrated Step Motor Drive Series from USAutomation
July 13, 2009 By Miles Budimir Leave a Comment
Laguna Hills, CA – USAutomation has announced the introduction of the Accuriss™ Series of fully integrated and packaged intelligent step motors. Accuriss motors combine a 1.8° hybrid step motor with a microstep drive and an intelligent controller in one easy-to-mount package.
USAutomation Accuriss Series
Measuring only 1.1 inches across, the Accuriss 28 is capable of microstepping at up to 1,600 steps per revolution, virtually eliminating the resonance inherent in step motors. The Accuriss 60 is 2.36 inches across and can microstep up to 51,200 steps per revolution. A high-level command language is embedded in the controller to allow users to execute real-time motion commands or write programs that can be executed with a start command, upon power-up, or via input signals.
Both Accuriss motors include programmable I/O ports. Communication to the motors is via RS485 and up to 16 units can be daisy-chained together. A USB-to-RS485 converter is a standard Accuriss option to allow users to communicate with standard USB ports.
Three different lengths of each motor are available allowing the Accuriss 28 to achieve up to 11 oz in of dynamic torque and the Accuriss 60 to achieve more than 300 oz in. The Accuriss 28 can be supplied as a standard motor option on USAutomation’s Microstage™ positioning system.
Accuriss motors can be programmed from any standard terminal program (such as HyperTerminal) or from the Accuriss Terminal™ program, a free dedicated terminal program available for Windows. Once the Accuriss is programmed it is capable of independent motion sequences with only the DC power source connected.
USAutomation also offers a wide variety of modifications to the Accuriss Series to help users design an ideal solution. These include custom connectors, cabling harnesses, and unique mounting provisions.
For more information, contact USAutomation at (949) 588-0513 or on the web at:  http://www.usautomation.com.
Filed Under: Controls, Stepper Drives, Stepper Motors Tagged With: step motor
