You are here: Home / Motors / Koford debuts 60-mm diameter 2-pole slotless brushless motor
Koford Engineering LLC has introduced a new 48-V 2-pole 60-mm diameter slotless sensorless brushless motor. The motor features 512 W continuous output at 15,792 rpm at 48 V with a peak motor efficiency of 93%. The 24-V version outputs 256 W at 7,560 rpm and has a peak efficiency of 92%.
These motors are also offered with Hall sensors and also the option of a temperature sensor. The motor is totally enclosed and made of corrosion resistant materials. The slotless design offers exceptional efficiency and power density with zero cog and linear torque behavior that is suitable for servo applications.
For more information visit www.koford.com.
motor
Filed Under: Brushless Motors, Motors
