You are here: Home / Networking + IoT / I/O / Lever-Operated PCB Terminal Strips from WAGO
Germantown, Wis. – WAGO’s new 2706 Series PCB Terminal Strips bring lever-operated terminations to compact electrical applications. 2706 Series’ inherently clear, tool-free operation eliminates specialty tools and torque specs required by traditional screw terminations. A UL/CSA 30A/300V rating and accommodation of conductors AWG 24-10 make 2706 ideal for inverters, power supplies and other field-wired applications.
Ranging from 2 to 12 poles, 2706 Series provides a lever for each pole. Lifting each opens a CAGE CLAMP Spring Pressure unit that remains open for conveniently terminating multi-conductor cables into the terminal strip. Lowering the levers creates an audible click, signaling that the units are secured. 2706 Series resists thermal-, vibration- and current-induced loosening common to screw-style terminations, eliminating preventive maintenance.
Pin spacing ranges from 7.5, 10 to 12.5mm; the 12.5mm variant achieves UL 600V certification. 2706 Series is available with jumper slots for potential commoning via optional comb-style jumper bars; additional accessories include test plugs and marker strips.
For additional information, visit www.wago.us.
Filed Under: I/O
