You are here: Home / Mechanical PT / Low-friction Gearbox for Higher Efficiencies
Bartlett, Ill. – Wittenstein announces a new version of its alpha SP+ HIGH SPEED gearbox, the L-Version. The new version features high maximum and nominal output speed, reduced nominal torque, lower heat buildup, lower no-load running torque and higher efficiency.
This low-friction gearbox is available initially for the HIGH SPEED versions of the SP+100, SP+140 and SP+180. The L-Version is ideal for applications demanding continuous duty with high nominal output speed and requiring longer service-life for continuous duty.
For more information, contact Wittenstein Engineering at [email protected] or visit www.wittenstein-us.com.
Filed Under: Mechanical PT Tagged With: Wittenstein
