You are here: Home / Motors / Servo Motors / MICROMO Introduces the FAULHABER Brushless DC‐Servomotors Series 1218…B
MICROMO announces the arrival of the new, high performance FAULHABER Series 1218…B Brushless DC Motor.  FAULHABER has expanded its high performance range of brushless DC servomotors to include the new Series 1218….B. It is designed to address applications where high power and overall motor size are key requirement. Its 18 mm length makes it the most compact drive on the market in the 12 mm diameter size. It has a wide standard operating temperature range from ‐20°C to 100°C. Based on the revolutionary System FAULHABER ironless stator winding design, the motor provides a reliable option for challenging fields of application such as medical pumps, robotics, and laboratory automation.
FAULHABER-Brushless-DC-Servomotors
1218…B servomotors deliver continuous torque up to 1 mNm and have integrated digital hall sensor feedback. When combined with the wide range of FAULHABER planetary or spur gearheads, the output torque can reach up to 300 mNm. For high precision positioning applications, FAULHABER zero backlash spur gearheads provide a compact alternative to reduce or eliminate undesirable mechanical play in the application.
MICROMO
www.micromo.com
Filed Under: Servo Motors Tagged With: MICROMO of Faulhaber
