You are here: Home / Integrated Motion Systems / Gantries + Stages / Microstage 28™ Positioning Stage from USAutomation
LAGUNA HILLS, CA — USAutomation has announced the design and introduction of the Microstage 28 ™ positioning stage serving a wide variety of markets and applications around the world. The Microstage utilizes a preloaded linear rail, a precision anti-backlash rolled leadscrew, a high performance coupling and motor mounting provisions.
The linear rail system supports radial and moment loads that are remarkable for the size of the stages. The leadscrew has no axial play and can accurately position within .0006” per inch of travel. The standard Microstage includes a coupling and a step motor so that it can be operational right out of the box.
Standard travel lengths are from 10mm to 205mm with 2 week leadtimes and custom configurations are also possible and encouraged for OEM customers with specific needs. The Microstage 28 is only 1.1 inches (28mm) across and easily mates with NEMA size 11 motors. The Microstage 28 is also available with USAutomation’s Accuriss 28™ integrated motor for the most complete micro positioning solution on the market today.
USAutomation
www.usautomation.com
Filed Under: Gantries + Stages, Linear Motion Tagged With: stages, usautomation
