You are here: Home / Controls / PLCs + PACs / Motion Controllers for Networked PLCs
★ By Jennifer Calhoon Leave a Comment
Advanced Micro Controls Inc. (AMCI), announces the addition of their ANF1 & ANF2 motion controllers with network communication, expanding their family of AnyNET Networked Specialty I/O products. AMCI’s ANF1 & ANF2 stepper/servo controllers integrate a network connection and expansion capabilities to provide a modern, versatile motion control solution for any PLC-based system.
amci-axis-motion-controlANF1 & ANF2 AnyNET I/O Motion Controller Features:
• 1-or-2 axis motion controllers
• Interpolated motion (circular & linear) available on ANF2 2-axis unit
• Use for servo or stepper control
• Choose EtherNet IP, Modbus-TCP, or Profibus-DP
• Compatible w/ today’s leading PLC’s or PAC’s
• Simplified programming via the host controllers’ native software
The AnyNET I/O ANF1 & ANF2 are fully featured 1 or 2 axis motion controllers that communicate with the host controller (PLC or PAC) over the EtherNet/IP, Modbus-TCP, or Profibus-DP network. The modules offer one or two independent motion control axes that function in an open-loop configuration, or closed loop using the available encoder feedback. Each axis can be used to drive a stepper or a servo with step/direction input capability. The ANF2 can synchronize its two axes, giving you the ability to control linear and circular motions in an XY plane. It easily mounts on a standard DIN rail, simplifying installation and lowering costs.
The ANF1 & ANF2 are compatible with any PLC that support EtherNet/IP, Modbus-TCP or Profibus-DP, and are programmed using the input/output registers within the host controller. No additional software is required to use the motion controllers with the PLC/PAC.
Expandable Motion Control: 1 – 12 Axes
AnyNET I/O easily expands from 1 to 6 I/O modules by stacking additional units onto the “gateway”, and only requires a single network connection for all communication. This solution enables the support of up to 12 motion axes over a single network connection, which reduces physical wiring and streamlines data traffic over the network.
AMCI’s fastest-growing product family, AnyNET Networked Specialty I/O, includes hard to find solutions for position sensing and motion control applications.
AMCI
www.amci.com
Filed Under: Controls, I/O, Networking + IoT, PLCs + PACs Tagged With: Advanced Micro Controls Inc. (AMCI)
