You are here: Home / Mechanical PT / Gears + Gearing / New Falk V-Class™ Gear Drives Line from Rexnord
Milwaukee, Wis. – Rexnord Industries announces the Falk V-Class, a new line of gear drives designed for maximum uptime and durable performance.
The Falk V-Class incorporates the latest advances in materials technology, engineering design, and manufacturing processes to produce a tough, reliable gearbox for demanding applications. These advancements, coupled with innovative mounting and cooling accessories, provide a reliable, sustainable gearbox. Features are built into the drive to provide maximum uptime in a smaller drive at a lower total cost of ownership (TCO).
One of the most distinguishable features of the Falk V-Class is the housing. The heavy-duty, horizontally split housing design incorporates advanced gearing, optimized through the latest materials and technologies, to provide maximum performance under load. The housing shape and features were designed through the use of Computational Fluid Dynamics (CFD), to enhance the drive’s superior thermal dissipation qualities.
Additional features were built into the Falk V-Class to increase productivity and profitability. The drive incorporates exclusive Magnum no-leak seals with oil drain backs and purgeable grease chamber to eliminate oil leaks. An optional, eco-friendly DuraPlate™ cooling system requires no water or electricity to operate and provides optimal cooling to fully use the unit’s torque density.
Rexnord offers standardized monitoring and lubrication packages, 24/7 customer support, readily available spare parts, and a product services team that offers onsite support, in addition to a 36-month warranty.
Learn more about the Falk V-Class at www.rexnord.com and www.falkv-class.com.
Filed Under: Gears + Gearing, Mechanical PT
