You are here: Home / Mechanical PT / Bearings / New Pillow Blocks from QBC
Garden City Park, NY — Quality Bearings & Components announces new pillow blocks featuring both locking collar and set screw types.
These pillow blocks, identified as the BBXBLK-HCP… and BBXBLK-UCP… Series, are made of cast iron housings, solid base dual seal type pillow blocks. They are designed to fit shafts ranging from1/2″ to 3-1/2″ in diameter. The height from the bottom of the unit to the shaft centerline ranges from 1-3/16″ to 4″. These standard duty units incorporate one lubrication fitting. These new elements make machinery efficient, more functional, and safer. Quotes plus online orders are available at the new QBC eStore.
www.qbcbearings.com
Filed Under: Bearings
