You are here: Home / Mechanical PT / New Sure-Flex Plus coupling cost savings calculator from TB Wood’s
July 19, 2017 By Miles Budimir Leave a Comment
TB Wood’s has created a new program that allows users to quantify just how significant the savings can be when replacing a copy-cat coupling sleeve with the high performance Sure-Flex Plus EPDM or Neoprene sleeve.
The program is now available at www.tbwoods.com or it can be installed as a smartphone app on any Android or Apple device. Users simply input their coupling current maintenance interval, cost of downtime, sleeve replacement cost, etc., and the program will reveal the cost savings that could be achieved by using genuine TB Wood’s Sure-Flex Plus sleeves.
The original Sure-Flex coupling design has recently gotten even better. New Sure-Flex Plus EPDM and Neoprene sleeves have a 30% higher torque rating, allowing many common applications to use a one-size-smaller coupling at an average 25% cost savings. This lowers the cost of both the initial coupling purchase and future sleeve replacements.
Extensive testing has shown that size-for-size, Sure-Flex Plus sleeves last more than 3X longer than the competition. The longer service life in demanding applications reduces required maintenance and associated replacement cost.
The Sure-Flex Plus sleeve design is 100% compatible with all existing TB Wood’s and competitive coupling flanges. Retrofitting a sleeve eliminates the need to replace the full coupling.
To find out more visit www.tbwoods.com.
Filed Under: Couplings, Mechanical PT Tagged With: Altra Motion
