Greenville, DE – Servo2Go.com has added new additions to it’s broad range of highly responsive analog and digital servo drives from Advanced Motion Controls. The ‘Z’ drives are µ-sized servo drives requiring less space than a standard business card and weigh about the same as two golf balls.
The ‘Z’ drives are capable of torque, velocity and position operating modes for brushed, brushless or voice coil motors. Inputs include: ±10V analog, PWM, Step/Direction, Encoder Following, RS-485/232 and CANopen network interfacing and much more. Some models are dedicated to operate in either torque or velocity modes only, for brushed or brushless motors only, and from certain command inputs only, reducing overall system costs by establishing a minimal feature set. However, these same units have extremely high current loop bandwidth for response time critical and challenging applications. Other models are fully configurable by the user to select torque, velocity and position modes as needed. These versions come complete with programmable I/O, flexible motor selection, ease of loop tuning, and optional networking such as CANopen, RS-485, and others. Complete configuration and diagnostics through set-up software is inclusive.
‘Z’ drives fit in a small 76mm x 51mm footprint and most weigh about 100 grams or less, including heat sink. Some versions can deliver up to 20A continuous or 40A peak current from 10 to 90 VDC.
More information on the New Z Series µ-sized Plug-in Module Servo Drives from Servo2Go.com can be viewed at:
