You are here: Home / Mechanical PT / Gears + Gearing / NORD Gear now sells MAXXDRIVE case size 14 gear units
September 23, 2016 By Lisa Eitel Leave a Comment
NORD Gear Corp. has expanded its MAXXDRIVE large industrial gear units line to include the case size 14.
The new size bridges the gap between the existing size 13 and 15. The size 14 MAXXDRIVE has a ratio range from 20:1 to 400:1 … and a max torque of 1,885,000 in-lb.
2016-nord-gear-now-sells-maxxdrive-case-size-14Available in both parallel shaft and right angle design, the MAXXDRIVE large industrial gear units offer a unique combination of flexibility and durability for the most demanding high-torque applications.
High ratios are possible by combining MAXXDRIVE with NORD’s CLINCHER or Helical-Bevel series to create a compound unit.  With dedicated product specialists on staff in Waunakee, WI, NORD provides knowledgeable and prompt support from design, engineering and assembly.  For information click here.
A developer and manufacturer of drive technology, NORD DRIVESYSTEMS is one of the world’s leading suppliers of gearmotors, electric motors, speed reducers and AC Vector Drives. NORD’s product portfolio ranges from standard drives to customized solutions for demanding applications. The U.S. headquarters is located in Waunakee, WI with two U.S. subsidiaries in Charlotte, NC and Corona, CA. With multiple assembly locations and an extensive distribution and service network, minimal lead times and customer-oriented service are always provided. NORD’s wide variety of gear types covers torques from 88 lb-in to 2,196,000 lb-in and more. The company also supplies motors with outputs from 0.16 hp to 200 hp and manufactures AC Vector Drives up to 125 hp. NORD’s AC Vector Drive products feature conventional models for installation in control cabinets as well as design types for fully integrated drive units in decentralized automation environments.
Filed Under: Featured, Gears + Gearing, Mechanical PT Tagged With: NORD
