You are here: Home / Mechanical PT / Gears + Gearing / NORD offers premium efficient alternative to industry-standard worm units
October 15, 2015 By Miles Budimir Leave a Comment
NORD Drivesystems’ new SK92.1 and SK93.1 series helical-bevels boast gear efficiencies of up to 97%. Typical right angle worm reducers range in efficiency from 40 to 90% depending on size, ratio and output speed. The increased efficiency of NORD’s two-stage bevels can result in as much as 30% energy savings.
NORD makes it easy to replace an industry standard worm unit with the SK92.1 or SK93.1 helical-bevel by ordering NORD’s optional industry interchange footplate. The footplate is available with either threaded or through holes and has an optional extended design to best suite all standard worm mounting situations.
NORD’s two-stage bevel drives have several other advantages such as a wide range of available ratios, a UNICASE, quiet, leak-free housing design, and wear-free infinite life gearing.
Visit www.nord.com for more information.
NORD
Filed Under: Gears + Gearing, Mechanical PT
