You are here: Home / Motors / Oriental Motor’s all new stepper motor and driver packages
★ By Jennifer Calhoon Leave a Comment
Oriental Motor is pleased to introduce our new CVK Series, compact standardized 24 volt DC input driver combined with performance driven, high torque stepper motors for the optimum application results. The CVK Series offers customers a common driver platform and wiring from which to choose the desired performance, allowing for improved machine performance while saving space and reducing costs.
The new CVK Series replaces our CMK and CRK round shaft open frame packages and features 2 motor types with 3 basic step angles. Choose from 1.8°, 0.72° or a 0.36° step angle, each with specific performance advantages. While the driver is matched to the motor type with maximum current setting flexibility, the driver size, mounting and wiring are common, allowing for easy testing and standardization. The 1.8° motor type offers the highest torque in the low speed range. The 0.72° motor type is designed to maximize the mid to upper speed range and the 0.36° provides superior positional accuracy compared to 1.8° and 0.9° stepper motors.
With the fully digital, standard full time microstepping driver, the lowest vibration is achieved throughout the entire speed ranges for all motors; especially low to mid ranges which are typical noise and vibration problem areas for stepper motors.
Oriental-MotorThe new CVK Series is available in five frame sizes: 20 mm (0.79 in.) to 56.4 / 60 mm (2.36 in.). For customers requiring a driver only, the CVD driver is also available with its wide range of adjustable current settings.
The CVK Series’ key features are:
• 50% more torque in the lower speed range for 1.8° motors
• 85% more torque in the mid and upper speed range for 0.72° / 0.36° motors
• Superior Positional Accuracy with the 0.36° motors.
• Low vibration due to fully digital microstepping driver
Oriental Motor
www.orientalmotor.com
Filed Under: Motors, Stepper Motors Tagged With: orientalmotor
