Portescap has unveiled the 32ECF brushless slotted flat motor, the latest addition to the company’s motor portfolio. This new motor has a diameter of 32 mm and an overall body length of 17.6 mm. With an 8-pole design and high-power density in a flat architecture, the 32-mm motor uses an outer rotor configuration with an air gap between the coil and magnetic structure that is managed radially.
The motor’s electromagnetic circuit has been optimized for higher performance, with a forty-five percent optimization of the motor regulation factor (R/K^2) as compared to standard available options. The motor also delivers a maximum continuous power of 32 W at 10,000 rpm within a 32-mm flat form factor, which is nineteen percent higher than many comparative solutions. As with any Portescap motor, options for customization abound.
The new 32ECF is a good choice for those working on next-generation projects, new programs, or future device iterations. The motor is best suited for applications that require a motion solution driven by performance but constrained by space, such as electric grippers, lab automation, infusion systems, service robots, and LiDar (Light Detection and Ranging).
For more information, visit www.portescap.com.
