You are here: Home / Mechanical PT / Bearings / Preassembled bearing units from NKE
★ By KRemington Leave a Comment
Easy to install, versatile combination options
Bearing manufacturer NKE presents its range of ready-to-mount bearing units. The bearing units that consist of a bearing fitted in a cast or pressed housing, offer simple, reliable and cost-effective bearing solutions for material handling systems like conveyors. They are also used in heavy and agricultural machinery as well as the steel industry.
The housings of the bearing units are made from cast iron or pressed sheet steel and can be combined with a range of different bearing inserts. Having a high stiffness, cast iron housings are resistant against deformation and can therefore absorb moderate to high loads. For applications with lower loads, galvanized pressed sheet steel housings are available. These have a much lower weight than their cast counterparts and are easy to install.
The bearing inserts consist of single-row deep groove ball bearings that are sealed on both sides against moisture, splash water and dust. Various seal types are available for different applications. The bearings are secured to the shaft with set screws or eccentric locking collars, which simplifies their installation. The bearings are factory lubricated and most bearing-housing combinations can be relubricated during operation to extend service life. The special version SQ171 is coated for corrosion protection.
Through the spherical design of the bearing’s outer diameters and the housing’s inner diameter, the units are self-aligning. This lets any misalignments that occur during installation or operation are compensated. NKE’s bearing units are interchangeable.
NKE produces standard and special bearings for all industrial applications. In addition to product development and application engineering, NKE provides a full range of technical services and training. NKE’s products are distributed through 15 international representative offices and more than 240 distribution outlets in 60 countries.
Filed Under: Bearings, Mechanical PT Tagged With: NKE
