You are here: Home / Encoders / Renishaw encoder compatible with Mitsubushi serial communications protocol
Renishaw (www.renishaw.com) has proudly announced that its Resolute absolute optical encoder can now be used in linear formats with Mitsubishi serial communication protocol. This enables the optical encoder to be utilized with Mitsubishi’s MELSERVO-J4 line of servo amplifiers, which are commonly used in various industries such as flat panel display (FPD) manufacturing, electronics assembly, factory automation as well as general motion control applications.
Renishaw-Resolute-absolute-linear-encoderAs a true absolute encoder, the Resolute delivers instant commutation for linear motors, eliminating the need for reference returns, in order to allow machines to be quickly re-started in a controlled and secured manner.
The absolute encoder also allows axes to be run harder and longer to maximize yield. Specifically designed with sub-micron accuracy, the Resolute linear encoders also feature high speeds of up to 100 m/s and a super-fine resolution of one nm.
These features enable PCB drilling machines and SMT machines and other electronic assembly and machinery to drill PCs faster, achieve higher components per hour (cph) ratings and reduce inspection times.
Aside from providing high accuracy and speed, the Renishaw encoders also excel in dynamic performance.
Its advanced optical scheme is designed to reduce short-term errors (known as Sub-Divisional Errors), which affect velocity ripple.
Akin to an ultra-fast, miniature digital camera, the Resolute absolute encoders employ sophisticated optics in order to read fine-pitched, single-track linear scales.
CE approved and RoHS/WEEE compliant, Renishaw’s Resolute absolute encoders are also offered in other protocols, including Panasonic, BiSS.
Read more about linear encoders —
including various ways to measue linear distances, how linear encoders improve accuracy, the first consideration in choosing a linear encoder, and IoT functionality with linear encoders — at linearmotiontips.com/category/linear-encoders.
Filed Under: Encoders, Linear Encoders Tagged With: Renishaw
