You are here: Home / Drives + Supplies / See it at ATX West: Applied Motion Technology’s latest motors and integrated drives
January 22, 2019 By Lisa Eitel Leave a Comment
Applied Motion Products will give personal demonstrations of its latest motor, stepper drive, and servo drive technology at ATX West … at the Anaheim Convention Center Feb. 5 to 7, 2019. Visit Booth 4264 to check out the following technology:
MDX Integrated Servo Motors that combine high torque density, low inertia servo motors with on-board drives and controllers to create all-in-one integrated motor solutions that save on space, wiring, and cost over conventional servo systems with separate motor and drive components.
StepSERVO Integrated Motors that provide cost-effective and high-torque motion control for high throughput applications such as packaging and labeling, automated test and measurement, and automated assembly.
STF Stepper Drives that support a range of industrial Ethernet and Fieldbus network protocols including EtherCAT, EtherNet/IP, CANopen, Modbus, Ethernet and RS-485, as well as a proprietary Serial Command Language (SCL) for efficient network communications over Ethernet (UDP or TCP) and RS-485. Using STF stepper drives, system designers and machine builders have the flexibility to control step motors using the network protocol of their choice.
SV200 Digital Servo Drives that operate on 24, 48, or higher dc supply voltages for space-constrained and multi-axis motion control applications.
Filed Under: Controls, Drives + Supplies, Featured, Industrial Automation, Industry News, Stepper Motors Tagged With: appliedmotionproducts
