You are here: Home / Networking + IoT / Sensors + Vision / Short, Self-contained Inductive Proximity Sensors from Balluff
Florence, Ky. – The SuperShorty® inductive sensor from Balluff is said to be the shortest sensor in the world that does not require an amplifier and will fit into a space as short as 6mm allowing it to fit in the tightest of spaces.
The SuperShorty offers the capability to install sensors directly into grippers or fast moving machinery, with frequency ratings up to 3 kHz, such as pick and place machinery – without adversely affecting their performance size or weight.  Although small in size and light in weight, some models weigh in at a mere 0.7 g, yet they still have all the features of standard size sensors.  All models are reverse polarity protected, short circuit protected, IP65 or IP67 rated and have a current capacity of 150 mA.
The SuperShorty is available in three housing styles; 6.5 mm smooth metal, M8 threaded stainless steel, and 6.5 mm plastic, all offering maximum flexibility in virtually any micro sized application.  The smooth or knurled plastic housing offers the user the ability to install the sensor by press fit or glue rather than mounting hardware or tapped holes.  With 90º cable exits, the sensors can also be used in the smallest spaces while eliminating cable bend issues.
SuperShorty inductive sensors with 1.5 mm sensing range are available in both PNP and NPN and both normally open and normally closed versions.  Connection options include cable out, M8 quick disconnect and pigtail versions with M8 connectors.
For more information on SuperShorty inductive sensors visit: www.balluff.com/supershorty
Filed Under: Sensors + Vision
