The STR3 miniature stepper drive from Applied Motion Products solves two problems in one:
The step motor drive addresses the problem of slow step motors that vibrate too much …
… and it addresses space-constrained applications where bulkier drives just won’t fit.
The STR3 utilizes a proprietary current control algorithm that optimizes motor performance, providing smooth motion over a wide speed range. Its extremely compact design means it’s possible to mount the drive just about anywhere, such as directly on the machine frame or tucked into small spaces between other components.
Designed for OEMs that require best-in-class performance and a high level of integration, the STR3 is intended to be used deep within the heart of the machine. Accepting industry-standard digital control signals (pulse & direction), the drive can be married to the widest range of embedded and discrete controllers.
Easily configured using dip switches, there is no software required for setup. Powered by 12 to 48 volts DC, it can be easily specified into mobile systems as well as onto the plant floor. Capable of providing up to 3.0 A/phase it can run a wide range of 2-phase step motors, from the smallest NEMA 8 to larger NEMA 23 and NEMA 24 frame motors.
Visit the product page on the microstep drive for more information.
Related items from Applied Motion Products on the Design World Network …
Applied Motion Products introduces integrated StepSERVO motors
Ideally suited for applications such as packaging and labeling, automated test and measurement, automated assembly and life sciences, StepSERVO motors from Applied Motion Products provide the next evolution integrated …
Shanghai Moons’ Electric Acquires Applied Motion Products
Shanghai Moons’ Electric Co., Ltd., announced that it has acquired Applied Motion Products, Inc. of Watsonville, CA. Applied Motion Products was founded in 1978 and specializes in providing…
Applied Motion Products Releases the IP65 Rated Step Motors
Applied Motion Products announced the addition of NEMA size 23, 24 and 34 stepper motors with IP65 ratings for operation in severe environmental conditions. These new models, dust…
PG Series of Planetary Gears from Applied Motion Products
Applied Motion Products is pleased to announce our new PG series of planetary gears. Custom designed for use with our new line of brushless DC motors, our first…
Applied Motion Products releases brushless DC motor drives
Applied Motion Products announces the release of their line of brushless DC motor drives. The BD5 is a brushless DC motor drive that is based on advanced control…
Applied Motion Products unveils compact STR2 Stepper Motor Drive
Applied Motion Products (www.applied-motion.com), a company specializing in cost-effective, high precision motion control products, has proudly introduced a digital step and direction drive ideally suited for OEM applications…
