You are here: Home / Drives + Supplies / VACON 100 FLOW for pump and fan applications
Vacon is announcing the VACON® 100 FLOW, an AC drive specially optimized for pump and fan applications. The new AC drive offers versatile flow control for water & wastewater and building automation applications, further strengthening the wide range of the VACON 100 product family.
VACON 100 FLOW combines the core design of VACON 100 with dedicated functions that can benefit flow control processes. The new AC drive also improves the efficiency and redundancy of pump systems, offering advanced features such as Multimaster and Multifollower for controlling multiple pumps simultaneously.
VACON 100 FLOW comes with many user-friendly features such as a fully graphical multilingual display, configuration wizards which enable easy setup of the drive, and intuitive built-in block programming functions which allow the AC drive to be tailored for special needs, such as use in retrofit installations.
Vacon
Easy system integration is made possible with industry-leading on-board Ethernet-based communication protocols such as EtherNet/IP, PROFINET IO and Modbus TCP, a Safe Torque Off (STO) function and ATEX-certified motor over-temperature protection.
VACON 100 FLOW uses environmentally friendly long-life plastic-foil capacitor technology which ensures highest reliability and lowest possible lifecycle cost.
Vacon
www.vacon.com
Filed Under: Drives + Supplies Tagged With: Vacon
