You are here: Home / Motors / Brushless Motors / 200,000 rpm brushless motor from Koford with air-cooled bearings
September 15, 2017 By Lisa Eitel Leave a Comment
Koford Engineering LLC now sells a new line of 24-v high speed motors with air cooled bearings for long life at speeds up to 200,000 rpm.
These motors are 48 mm in diameter and are very quiet. Continuous power up to 85 W is possible. Applications include optical devices and high-speed blowers and pumps. Beam choppers can be operated at reduced pressure since the motor only uses air at 0.1 cfm and 1.25 psi. A standard diaphragm pump can reduce pressure in a chamber by 90% resulting in reduced power requirements. For more information, www.koford.com.
Filed Under: Brushless Motors, Featured
