You are here: Home / Motors / DC Motors / The relationship between voltage and dc motor output speed
The operation of a DC motor is relatively straightforward. A coil is placed in a magnetic field, and when an electric current passes through the coil, a torque is produced, causing the motor to turn. The entire process is driven by applying electrical power to the coil, with the source voltage having a direct relationship to the motor’s output speed. To understand this relationship between voltage and speed, let’s look at a typical brushed dc motor circuit.
DC motor
DC motor circuit. Image credit: Precision Microdrives Ltd.
The applied voltage equals the voltage drop across the coil resistance, R, and the inductor, L, plus the back-EMF.
DC motor
Where:
V = applied voltage
I = current
R = resistance
L = inductance
E = back-EMF
The voltage equation can be simplified by assuming that the current is constant, in which case inductance can be disregarded:
DC motor
The back-EMF (electromotive force) is a voltage that is generated by the rotation of the coil. It opposes the applied voltage, reducing the voltage flowing through the motor.  Back-EMF is calculated as:
DC motor
Where:
kE = electrical constant, inherent to the motor
ω = angular velocity of the motor
Substituting for E in the voltage equation, we get:
DC motor
The current, I, through the motor coil is directly related to the motor’s torque:
DC motor
Which can be rearranged as:
DC motor
Where:
T = torque
kT = torque constant, inherent to the motor
Substituting for I, the voltage equation now becomes:
DC motor
This shows the direct relationship between the applied voltage and the motor’s angular velocity. Rearranging to solve for the angular velocity:
DC motor
For DC motors, the torque and electrical constants, kT and kE, are equal, so the angular velocity equation can be simplified to:
DC motor
From this we can see that the motor’s maximum speed occurs when there’s no load (torque) on the motor.
Rearranging for torque:
DC motor
Similarly, maximum torque occurs when angular velocity is zero.
These two relationships can be seen in a typical DC motor’s torque-speed curve.
DC motor
DC motor torque-speed curve
Image credit: National Instruments Corporation
Back to the original question:  how does voltage affect speed? From the analysis above, we can see that when the load (torque) on the motor is constant, speed is directly proportional to supply voltage. And, when the voltage remains constant, an increase in the load (torque) on the motor results in a decrease in speed.
Feature image credit: MICROMO
Filed Under: DC Motors, FAQs + basics, Motors Tagged With: DC motor, motor, speed
