You are here: Home / Motors / DC Motors / What’s the relationship between current and dc motor output torque?
Torque is a rotational force produced when a vertical force is applied at some distance from the center axis of the rotating body. The familiar equation for torque is:
DC motor
Where:
T = torque
F = applied vertical force
d = distance from axis of rotation
In a DC motor, the output torque is directly proportional to the current through the windings, and is given as:
DC motor
Where:
I = current through the windings
kT = torque constant (specific to the motor)
To see how this relationship is developed, let’s look at the geometry of a DC motor:
DC Motor
A 4-pole DC motor
Image credit: electrical4u.com
The force on one coil is the product of flux density, current through the coil, and the length of the coil:
DC Motor
Where:
Fc = force on one coil
B = flux density
Ic = current through one coil
L = length of the coil
The current through one coil is calculated as:
DC motor
Where:
Ia = total current through the armature
A = area of the coil
Substituting for Ic in the force equation, we get:
DC motor
Because torque equals force times distance, the torque equation can be shown as:
DC motor
Where:
Tc = torque on one coil
r = distance from center of armature
The flux density, B, equals the total flux divided by area:
DC motor
Where:
φ = total flux
Because the motor is essentially a cylinder, area is calculated as:
DC motor
Where:
P = number of poles
Substituting into the flux density equation, we get:
DC motor
Substituting this into the torque equation, we get:
DC motor
Which simplifies to:
DC motor
Tc is the torque on just one coil. Total torque equals Tc multiplied by the number of coils:
DC motor
Where:
T = total torque
Z = number of coils
To further simplify the torque equation, the number of poles (P), the number of coils (Z), and the geometric factors (2πA) can be combined to form the torque constant, kT, which is specific to the motor.  This simplifies the torque equation to:
DC motor
For most DC motor cases, we can assume the flux, φ, is constant, making torque directly proportional to the current:
DC motor
When examining the torque-current curve for a DC motor, notice that the no-load (stall) current is greater than zero. This is because some current is needed to overcome the internal friction of the motor.
DC motor
Torque-current curve for a DC motor.
Filed Under: DC Motors, FAQs + basics, Motors Tagged With: current, DC motor, torque, torque calculation
