Galil now offers an EtherCAT slave I/O module.
This new product is about a third the price of competitive products … as other
EtherCAT I/O solutions are $1,400 to $1,800 on average. More specifically, the prices for the two versions —the RIO-57410 (No Analog I/O) and RIO-57420 (With Analog I/O) — are:
$495 for one or $345 for quantities of 100 of the RIO-57410
$595 for one or $395 for quantities of 100 of theRIO-57420
Suitable for use with the DMC-50000 EtherCAT Master, the EtherCAT slave I/O module also works with any generic EtherCAT Master.
Full details can be found at galil.com/plcs/remote-io.
The RIO-574×0 is a compact, cost-effective EtherCAT I/O slave module. It is packed with digital and analog I/O to be used remotely in an EtherCAT automation system. Although the RIO-57000 can be used with a generic EtherCAT master, it is designed to integrate seamlessly into an EtherCAT system with Galil’s DMC-500×0 EtherCAT master. More after the jump.
Each RIO-574×0 has 16 opto-isolated digital inputs and 16 high-power, 500-mA sourcing, opto-isolated digital outputs. The RIO-57420 is expanded to include 8 analog inputs and 8 analog outputs, both configurable in the ranges of 0-5V, 0-10V, ±5V, or ±10V.
The RIO-574×0 can be configured over USB in a few steps using Galil’s software and intuitive english-like 2 letter commands.
Related: New DMC-30016 Pocket Motion Controller from Galil
Galil Motion Control is announcing their latest drive option for the DMC-30000 Pocket Motion Controller Series. The new DMC-30016 combines a single-axis motion controller with a 1.4A/phase stepper…
Related: Galil Introduces GalilSuite Software Revision 1.0
Galil Motion Control is announcing its GalilSuite Revision 1.0 Software Package. This is their latest generation software for configuring, analyzing and tuning Galil’s motion control systems. GalilSuite replaces…
Related: Single-Axis Motion Controller with Microstepping Drive from Galil
Galil Motion Control has introduces a stepper motor drive option for the DMC-30000 Pocket Motion Controller Series. The new DMC-30017 combines a single-axis motion controller…
Single-Axis Controller with 800W Sine Drive from Galil
Galil Motion Control introduces the DMC-300xx Pocket Motion Controller Series, a single-axis Ethernet motion controller. It combines a high performance motion controller …
Servo2Go Adds New DMC-1417 Econo PCI BUS Motion Controller from Galil
Servo2Go.com has added Galil Motion Control’s new PCI BUS Econo Motion Controller, the DMC-1417, to its broad range of PCI-based motion controllers …
Servo Drives with Sinusoidal Commutation from Galil
Galil Motion Control, announces two multi-axis servo drives that perform sinusoidal commutation; the AMP-43540 with four 600W servo drives, and the AMP-43640 with four 20W…
Galil unveils Ethernet motion controller
