You are here: Home / Encoders / Incremental Rotary Encoders from Pepperl+Fuchs
July 29, 2009 By Motion Control Tips Editor Leave a Comment
TWINSBURG, OH – Pepperl+Fuchs introduces RVS58S Incremental Rotary Encoders with integrated safety technology. RVS58S encoders with self-diagnostics are specifically designed for use in safety aligned systems up to SIL3 in accordance with IEC 61508, performance level “e” in accordance with IEC 13849, and Category 4 in accordance with DIN EN 954-1. They are also suitable as a motor feedback system for safe drives in accordance with IEC 61800-5-2.
In response to these needs, Pepperl+Fuchs developed the RVS58S rotary encoder with functional safety that enables economical system integration. This new concept provides easier connection methods to the control system and allows it to be used in high safety category systems. Technically speaking, RVS58S incremental encoders have a sin/cos interface, 1024 or 2048 signal periods, and are thermally stabilized for high resolution interpolation. They operate at 5 VDC ±5% and deliver a maximum output frequency of 200 kHz in operating temperatures ranging from -20 °C …80 °C (253 K …353 K). They are rated to handle axial shaft loads of 40 N at maximum 6000 RPM or 10 N at maximum 12,000 RPM, and radial shaft loads of 60 N at maximum 6000 RPM or 20 N at maximum 12,000 RPM.
The industrial landscape is populated with ever faster high-performance machines, in whose environment a whole range of robots and automatic feed systems are also operating in order to ‘unload’ the operating personnel. In any application where such systems are in use and moving machinery parts are driven by high-performance systems, there is the potential for danger to the operating personnel. According to the Machine Directive and relevant safety regulations for health and safety in the workplace, even brief lapses in attention must not result in shearing, crushing and impact injuries – or worse. The preferred use of rotary encoders in such applications is to monitor rotating or swiveling components in drive systems, making them a core safety consideration in drives.
In order to keep the expense of safety measures within limits, rational safety concepts will increase in importance in the future. Consequently, in this context the functional safety of individual system components, such as rotary encoders, assumes new significance. This transpires against the background of a changing situation with regard to standards, since the standard EN 954-1, which has been binding since 1996, remains valid only up to 29.12.2009.
The deterministic approach of EN 954-1, of countering the deduced risk categories by means of an appropriate system behavior, will now be superseded by the more effective standards EN ISO 13849-1 and EN 62061. With their consideration of failure probabilities (probabilistic approach) these are also more in keeping with the requirements of modern programmable electronics, which has long been subject to the considerations of safety technology. The IEC 61508 serves as the higher-level standard for functional safety.
Since the architecture determines a significant proportion of safety costs, smart ideas can reduce these costs while even increasing the efficiency of sensor-system safety. The use of mechanisms featuring two-channel operation, without completely duplicated execution of the functional units, is an effective approach. However, even systems with two rotary encoders or a dual encoder do not necessarily have to be classified according to the new standard. In order for a sensor to receive a high safety evaluation, it must be ensured that the Safe Failure Fraction (SFF) and the degree of Diagnostic Coverage (DC) are appropriate to comply with the minimum requirements. Self-diagnosis implies that the device is able to detect its own fault conditions and then reliably communicate the same. In this way machines and control systems are able to immediately carry out a defined stoppage, before subsequent failures of any kind can lead to a dangerous situation.
Pepperl+Fuchs
www.pepperl-fuchs.com
Filed Under: Encoders, Rotary Encoders Tagged With: Pepperl+Fuchs
