You are here: Home / Mechanical PT / Gears + Gearing / Lenze Hybrid g500-H helical gearbox delivers more robust performance
Lenze Americas now sells an optional output flange to its leading-edge g500-H series helical-inline gearboxes.  The new reinforced VCP (viscous combined plate) output flange provides superior radial load capacity.
The Lenze g500-H series output flange effectively isolates forces from our CAD-optimized aluminum housing.  The result is an even more robust and accurate solution, with a radial load capacity higher than previous generation, iron-based housing designs with reinforced bearings,” says Alby King, project manager of electromechanical products at Lenze.
The new hybrid design includes an output shaft supported by traditional reinforced tapered bearings and the inclusion of a final drive-gear support bearing.  The innovative output flange was designed for applications demanding higher output shaft radial loads.  Ideal for many industrial applications, the entire Lenze g500-H helical gearbox series features CAD-optimized design, closely stepped speed reduction ratios and a low backlash. More after the jump.
The Lenze g500-H series is closely scaled in terms of size and torque, with standardized shaft and flange dimensions for easy machine integration.  A lightweight and compact package, g500-H series gearboxes are available in two-stage and three-stage designs with a maximum torque of 450 Nm and ratios up to i=370 depending on the application requirements.  The g500-H can achieve efficiencies of 94-96 percent or more across the entire operating range.
“Lenze brings real-world expertise and proven motor drive technologies to customers,” adds King.  “The g500-H with the new output flange option combines seamlessly with our Smart Motors, MD three-phase AC motors below 1 hp, IE3 m550P three-phase AC motors, inverter-optimized MF motors, and MCA and MCS servomotors to form a powerful drive unit in demanding machine tasks.”
About Lenze Americas
Lenze is a global manufacturer of electrical and mechanical drives, motion control and automation technology. As a global specialist in Motion Centric Automation, we offer our customers products, drive solutions, complete automation systems, engineering services and tools from a single source. We are a leading provider of automation solutions to the packaging industry, and our other focus industries include automotive, material handling and logistics, robotics, and commercial pumps/fans. With a global network of engineers, sales representatives, and manufacturing facilities, Lenze is well-positioned to meet the motion control needs of customers worldwide. Lenze Americas, the American subsidiary of Lenze SE of Germany, is headquartered in Uxbridge, Massachusetts, with an assembly and logistics center in Glendale Heights, Illinois.  Corporate global headquarters are in Hamelin, Germany.  Visit www.lenze.com for more information.
Filed Under: Featured, Gears + Gearing, Integrated Motion Systems, Mechanical PT, Motors Tagged With: Lenze
